I was wondering how difficult it is to remove the oil filter relocator on the block? I have a pretty good leak outta there I need to fix but it looks pretty tight under there...any advice to make it easier to remove would be appreciated.
I've done a dozen of these. It's not that bad. You don't have to remove the P/S or alternator bracket, and removing the wheelwell gains you nothing for this task. Removing the front driveline isn't necessary, either. If the lines aren't leaking, you don't have to remove them. But they come out without removing anything even if they do have to come out.
1. A long extension and a swivel13MM socket helps to remove the bolt that holds the lines to the adapter.
2. Remove the clamp (13MM) bracket that holds the lines by the P/S pump so the lines can be wiggled around.
3. Remove filter relocator.
4. Put it back together again.
The GM P/N for the kit with the gasket and the O-ring for the adapter is 88893989. It isn't as hard as these guys made it sound. Go for it.
only thing is I can't change the oil with the motor warm, but that's no big deal
Why not?
I haven't had my oil cooler at all for my new build but can't say I have been driving it long enough to notice any issues. FWIW, everything seems fine after 3000 miles.
I have to tip the filter over on its side to get it around the propshaft and that sucks doing it with hot oil
