can you guys tell me if my turbo is stock from these numbers i got off it? on the front it says 49179-54 and on the back it says 4F09B. would those numbers be any help?
oh and where is the oil pressure sending unit? on these?
thanks nick
I still think after seeing it, its 20g but not 100% sure, i just dont get that on Justins his stock boost controller silyniod is on the top like my TY and yours is on the bottom.
where did it come from? the color of the turbine housing looks like the ones I build, the wg arm looks straight in whcih case makes it a 20g wg actuator and comp cover.
well it's clearly a mitsubishi, with an aftermarket wastegate actuator and what appears to be a 2.25" compressor cover since i still see the stock inlet hose... Other then that it may be difficult to decipher exactly what lies inside..
As for the oil pressure sending unit it is located next to the distributor...
