Re: Maybe dumb / Maybe not / Tried Searching Intercooler as Trans Cooler ??
If you look at old threads from back in the day, you'll see that people were originally using trans coolers as aux ICs. Somewhere along the line, people figured out that the small, high-pressure lines in the trans coolers didn't really match well with the characteristics of coolant in the IC system. They switched to heater cores, which are designed for dumping heat out of coolant.
Using the CCHE as a trans cooler is sort of the exact same situation in reverse. The CCHE probably doesn't match the profile of cooling ATF very well (in addition to the simple pressure concerns already mentioned).
But if you're going A2A, you could adapt a trans cooler to the factory CCHE location. You'd obviously want to be careful of debris down there though. Losing your IC wouldn't be good, but losing all your ATF would suck a lot more.
