Matt's Twin Turbo Sy build
Matt
Hi guys i thought i would start a thread to keep me motivated and to fill others in on my project Sy #1207, the truck i got from a local member with a hurt engine, then picked up a fully built bowtie From LILQIK my goals are for around1200hp and 9s
The Syclone
The Engine
304 cubic inch
Bowtie Block w/ Billet Caps front to back
Even Fire Billet Sonny Bryant Crank 3.750"
Oliver Billet Rods 6.000"
Diamond Pistons (coated) 4.140"
Block fitted with piston squirters
Brodix Raised Runner Heads 310/240 cfm
Jesel Shaft Mount Rockers 1.6"/1.8"
Daytona Dash Intake (matched to Heads)
Jesel Belt Drive
Titan Billet Pro Series Oil Pump
Custom Billet Cam 258/258 @ .050 on a 115LS .675"/.750" lift (with current rocker ratio's)
Sheet Metal Valve Covers w/ Coils
Sheet Metal Oil Pan w/ Dipstick
Rpm custom twin turbo headers
A few engine pics
Headers
Trans
4L80E
Circle D converter
Engine Management
Big Stuff 3
Tuned By Nolan
Suspension
Rpm coilovers up front
beltech drops leafs with caltracs out back
My plan is to still be able to drive it on the street on the weekend on low boost and turn it up and hit the track, not too sure how streetable it will be, the engine made 450hp N/A with a carb on a break in run, so even out of boost it will be fun.
some of the other details are still in the works as i work with Nolan at Moretto Motorsportz http://www.morettomotorsportz.com/ to make this thing a monster
nallj92
Re: Matt's Twin Turbo Sy build
awesome, Look forward to the build and more pictures!
which intake you going to run, the dash intake or the sheetmetal one?
Matt
Thanks, Undecided as of yet thinking the sheet metal one, might have to let the Dyno decide ; )
STOUT74
Nice lookin' build Matt. What size turbo's you thinking of running. What are you going to fuel the beast with, Petrol or Ethanol? Love the stance from the rear with the 11's. Good luck & way to represent:tup:.
Matt
62mm Precision billet CEA 6266, good for 750hp each, 94 octane and methanol injection on low boost, C-16 on high
hatrik8
Nice steamroller wheels. :tup: Why does it look crooked from the rear? Is it the camera tilted?
nallj92
Let me know what way you decide on intakes. I may be interested in one or the other.
Matt
looks like i may be running the dash intake, i am going to hold on to the other one for now, i ordered my 160lb injectors today :woot:
90pgt
The front off that engine looks very nice and clean, what a/c compressor is that, Is that the stock sy acc. bracket, do you happen to have a part# for that belt drive?
sy605
Love the build. No offense to Mr. Syclone but I would love to see the record for fastest V6 Sy back in the states.
Good luck!
