Re: Later Model GM Deck?
not without some work.
The chassis of older 1.5 DIN radios like ours is different from the later 90's /early 2000's 1.5 DIN radios. The brackets that hold our radios in place have nowhere to bolt on to the later radios, so a custom mounting solution will need to be created.
Also the radio harness is different, which is not a huge deal. Just have to get a Metra 70-1677-1 and wire it to a 71-1858.
The antenna end is different as well. Our trucks have the standard size motorola antenna end at the radio. After 94 I think, GM went to the mini-motorola end. A Metra 40-GM21 will take care of that.
You should be able to use most GM 1.5 DIN radios up to 2001-2002 or so. After that they went to the CAN-BUS radio turn on.
