Hypothetical turbo question
Black Knight
I Glow Therefore I am
Hypothetically speaking if in the future if I was planning on upgrading my turbo to a much larger one (70's ish mm, something large enough it would destroy a stock motor if you ran it at its full potential) is there anything wrong with running one, but just running extremely low boost like 1-5lbs (whatever the stock motor could safely handle)?
Now assume you have all the other supporting mods associated, just not a built motor. Torque converter is proper size for turbo, larger injectors (if you even need them since the motor isn't going to be pushed any harder then a stock one), obviously the correct tune, etc.
Is there anything wrong with this logic? I've been thinking it over quite a bit and if I ever got around to getting a larger turbo I would prefer to doing it once as apposed to twice (one for what the motor can handle now and one for what it would be able to handle in the future when it finally craps out and gets upgraded).
Plus the awh factor of a larger turbo is always cool, no one needs to know its only running one pound of boost, lol :rotf:
Black Knight
Re: Hypothetical turbo question
Oh gotcha, so even with a really high stall the motor itself wont be pushing enough air through it to spin that large of a turbine.
qbnkiller
Conflaguration Specialist
a large turbo at low boost will not be responsive whatsoever, along with it not producing much power.
If you want a turbo big enough to blow your stock motor up, you already have that! A poorly tuned truck will eat itself with the stock turbo. A better question to post is what your horsepower goals are, what fuel you wish to run on, and what your thoughts are for driveability. Then the responses you receive can be more thought out and well-balanced.
Black Knight
I thought my question was a good question :lol:
I don't want to blow the motor up, I'm purely trying to figure out if a stock motor can handle a very large turbo "well tuned" at low boost.
Like I said before assume tune is spot on, the stock turbo runs out before it becomes dangerous to a stock motor. Assuming everything is good, fuel, tune, etc. you can run the stock turbo up to mid 20's+ in boost and the motor will hold up and any higher the heat created just hurts you. So then you step up to a larger turbo (again reason for the question because I don't want to take 2-3 small steps just 1 big one) but if it doesn't work because of "X" factor that's what I'm trying to figure out.
I'm confused on what your saying in regards to a large turbo at low boost wont be responsive. How long does it take a large turbo to reach 1-5 psi? It's really that much longer then the stock to reach 25psi? I really don't know, never been in a big turbo SyTy. I understand what everyone is saying about it not pushing enough air to spin it in the first place that does make total sense.
1.) Horsepower goals: Don't care, my end result is the largest turbo your can get keeping the A/C (from what I understand it a 72mm). A goal would be say to be in the 10's but no other reason then it sounds cool. I have no power goal in mind, just wherever I end up.
2.) 93 - 100 octane fuel with alcohol injection.
3.) Not to concerned with driveabilty, I don't drive it often anyway.
qbnkiller
Well, my thoughts are a bit different. If you want the best bang for the buck, try to select a turbo that has the most area under the curve. Something that gets on boost pretty quickly (without having to get into a high-stall converter) and can be turned up to make more power if need be. Our trucks are torque machines. In stock trim, they run out of breath by 5,000 rpm. If you were to do nothing else, a large turbo (tuned properly on all stock internals) would start making power around 4,000 rpm, making your power band very narrow. You will quickly start to dislike the combination!
I run a turbo from a company called Bullseye Power. Its a 62mm T3 turbo that makes great power for its size. I have made almost 600RWHP with it, and I can still turn it up more. On the street, it's incredibly quick to spool. I know not many people are familiar with the company, but after HC next week, I think more people will be giving these turbos a closer look.
I have run in the 10's with my Typhoon on one of their 62mm turbos. With your lighter Sy, that should be no problem! Build a better-breathing engine, and turn it up!
HTH
denny
HTH
Congratulation on the 10s, how much more you think you can get out of the 62mm?
qbnkiller
It should make power on this combo up to 30-32# before I think she'll run out of breath (about another 100WHP or so) - but time will tell!
vortecfiero
a lot of the larger compressors are not very efficient in the low to med boost (5 - 10 lbs)
on certain size engine and rpm ranges etc. You may just be heating up the the air
more than you should be if its in the 50 to 60% range. Believe me even at 5 lbs of boost
65% to 70% feels a lot stronger and the engine/exhaust runs cooler.
the difference could be as much as 20 to 30 deg F
for a street machine sizing a compressor with peak torque and peak hp really close
to either side or in the peak efficiency island and making sure that has it has a fairly tall
island will go a long way to ensure that in the future, when you plan to run more boost,
you will probably still be in a good area on the compressor map across your rpm range
it all depend on your goals though... broad range or peak power and with careful planning
some compressors can do both with little or no compromises.
Brassmonkey
Cruzin' Mel Man
I think what most people are trying to say is, your truck will run, but not well and it would be a waste of t a big turbo.
It's just a six
Super Member
You can always use a smaller turbine housing A/R to get a larger compressor to spool up just fine,,then later you can change the turbine housing w/a larger A/R, when you have all your mods set-up & installed.
I have done it w/my Mitsubishi turbo, 8 cm housing w/a 20G wheel & 8 cm housing w/a 60-1 wheel & 12 cm housing w/a 20g wheel & a 60-1 wheel.
Running such a small turbine housing (8cm) ,really did not spool up any slower even w/the larger 60-1 wheel,,,,but it sure did choke up the mid & top end. Drivebilty was the same w/the 8 CM housing w/the 20 g wheel or the 60-1 wheel.
