Getting ready for spring?
Matt
Hi guys just curious what everyone has been up to on their trucks over the winter and if they will be on the road come spring? i am in the process of doing a 80E for my Ty and hoping to have it on the road by May :lol:
Matt
bezerk
Re: Getting ready for spring?
can't get myselve to work on my trucks, need to pull an engine, and the other truck needs a manifold gasket replaced.
damn winter
Static
Installed:
Silicone vac kit
Engine Tiedown
DutchTy lower cooler upgrade with new Johnson pump and rubber lines
Turbo to IC hardpipe
Battery relocated to lower fender
PLX Wideband o2
Propshaft loop
Removed Ultimate chip
Installed Ostrich 2.0 getting ready for code$59
Hope to have it running again soon, or at least for Nats. I need to extend the battery cables and start tuning and hopefully resolve the knock issues I was having. I really should be working on it right now but hurt my back at work.
Still to do:
Steering shaft upgrade
cold air box
fuel pump
3"downpipe, cat and muffler
LS1 brake upgrade
gary sy
i call it SYCLONE FEVER in the spring when im just itchin to drive it pretty soon i cant wait! :D
bezerk
with 1 truck i'm kinda waiting for the track to go open. be a big gun :D
Kybol
I did nothing to mine all winter, although I finally took it for a drive today, and then thought I should check out syty.net
Storm Warning
I had the engine rebuilt in the Ty a few months ago. Runs very strong now to say the least. I ported my L35's (bowl work) and had them machined for guideplates for use with 1.6 roller rockers, had my stock cam reground to my specs, and replaced my old 20G with a brand new 20G. Got the exhaust housing (14cm) black ceramic coated and the wastegate hole machined out and a larger puck installed (for better boost control). Still running the stock injectors set at 60 psi, runs well but bigger injectors are needed.
Dr.Gixxer
Motor is almost installed but still need to pick up my alky control kit as well as some other goodies, have to finish building my 80e but thats tough when I am 8 hours away from it.......Uggg I still have lots to do.
werbicki
<User Title Goes Here>
Same here, just pulled the SY out this weekend and took it for a spin and now I need to catch up on the board after a winter hiatus. Feels good to be back on the road, especially with the new transmission!
Paul
LawnGnome92
over the winter mine got a zq8 steering box belltech rear sway bar and after the frist autocross event in back in march i had to replace all the ball joints.
Darin
Plans so far include some basic maintenance and to actually put some of the stuff that I have sitting on the shelf on the truck. Boost controller, springs, etc, etc, etc.
Suny
So far, new wheels, front brakes, idler arm, new shocks, rear axle seal orderd, rear diff pan gasket purchase, need to get some rear shoes, transfilter purchased, also needs transfercase oil and front diff oils. got some speakers to be installed might just sell that with all the stereo stuff since it cant play off my iphone.
