GEN3Typhoon
1992 GMC Typhoon #0488
Aspen Blue, reported to be less than 50 Aspen Blue produced
110,000 miles
Speedhut Indiglo Gages
3 Gage A Pillar Pod
Dash Cover
OE Concepts Chrome ZR-1 Wheels (F 17x9, R 17x11)
Tires are included but are not in good shape
Also includes a set of stock wheels with two used tires
Eaton Posi Rear Differential
Richmond Locker Front Differential, rebuilt with new bearings and seals
New Hydroboost Brake Master Cylinder and Booster
LS1 Car Front Disc Brake Conversion
LS1 Car Rear Disc Brake Conversion, Including rotors
New Braided Stainless Lines
JS Manufacturing Coil Over kit, QA-1 shocks and front chromoly arms
Remanufactured steering box with Corvette ratio
Flaming River Steering components
Stock 700R4 Trans and BW4472 Transfer Case Included, both have 110k miles on them.
Transfer case is reported to work properly; transmission is reported to slip on the 3-4 shift.
I also have an LS1 engine with harness and PCM. This truck also has the engine
mounts and oil pan installed that are required for the Typhoon installation. Engine has Katech rod bolts installed and corvette accessories. Also has a Futral turbo friendly cam installed.
Complete upgraded 4L80E with Typhoon conversion parts and a stock truck converter.
Take the truck, the engine, transmission and everything for $8000
110,000 miles
3 Gage A Pillar Pod
Dash Cover
