What got me thinking of it was I was considering removing them for cerakoting anyways, def pricey though.. I had a stock motor rebuild on my old 87 turbo t, previous owner had the intake extruder honed, my engine builder who had done a ton of turbo buicks kept telling me how nice the manifold was insideI considered it while building a fresh engine. The intake and exhaust already flow better than the stock heads, so there isn't much benefit. If you can get it done for free, you might see some improvement in spool response from having the exhaust manifolds done, otherwise there are better parts of the truck to spend money on...
When I look under the hood it's a bit daunting, not sure where to begin lol.. Extrude hone though is a process where they hydraulically inject an abrasive putty through all the passages resulting in a really smooth surface in theory making better air flowremoving the intake and exhaust should be pretty straight forward. I am unfamiliar with what extrude honing is tho...
From my understanding, a slightly rougher surface is better for a lower intake as it helps atomize the fuel. (see pics of my lower porting) This is the same when I ported my heads, I left the intake ports a little rougher but polished the exhaust ports smooth.
As for the stock exhaust manifolds all I did was port match, I'm told the stock manifolds are good for up 700hp. Not sure how much extrude honing will add.
On port injected motors, like the Sy/Ty, there is no fuel in the intake ports, that would need help antomizing. If you're worried about the fuel atomizing, get better injectorsFrom my understanding, a slightly rougher surface is better for a lower intake as it helps atomize the fuel. (see pics of my lower porting) This is the same when I ported my heads, I left the intake ports a little rougher but polished the exhaust ports smooth.
Good advice thanks.. I may just swallow my pride n have my mechanic friend do the r&r in his shop, I'll slap in a few led fixtures n call it a wash.. far as the turbo porting yes sir all part of the plan, I just worry I'm gonna live to regret Dave P's sage advice of leave it the fuck alone lolNot sure if this adds any insights... https://howtune.com/articles/43-port-matching-the-turbo-on-a-gmc-typhoon
Intake isn't bad coming off, make sure to label all the connections. Exhaust is just tight...always easier on a lift if at all possible. Lot of back and forth when it's on jacks that makes it hard.
On that note.. I realize the factory (30 lb?) Injectors are perfectly matched for a stock setup, but do the new 42's that are available perform (atomize) any better? Disk vs pintle etcOn port injected motors, like the Sy/Ty, there is no fuel in the intake ports, that would need help antomizing. If you're worried about the fuel atomizing, get better injectors
Pintle injectors have better spray pattern then disc injectors, but are more prone to lock up, when running them on higher fuel pressureOn that note.. I realize the factory (30 lb?) Injectors are perfectly matched for a stock setup, but do the new 42's that are available perform (atomize) any better? Disk vs pintle etc
