Re: Drop leafs?
Well it depends on how heavy your rig is and how stiff the springs are, and partly the corner heights too. I've always needed blocks with my 3" drop springs belltech and flex-a-form, except for when I had my 31s on there a few years back. When i switched to normal size 29" tires on vette rims, it left a pretty big wheel gap. The only way I will eventually be able to get my weight balanced right and the corners all the same height is with roughly 3.5" of block on top of my flex-a-form 3" drop spring.
Do you have the front at the height you want and what are you using?
