when i put the truck in neutreal , when still moving someting in the rear end makes a clank noise, it sounds like the rear end, the trans is allready screwed, so i am just curious if it is the trans, or if i may have screwed something up, when putting the rear end back together. also, when i stop in traffic, if i put it in neutrel, & not touch the gas, it will idel foward.if i touch the gas, it jumps, then falls in to neutral, & agin makes a clank noise. Just wondered if any one else had this happen
A little off topic, but does any one else have a feul pump that can be heard over the engine at idel, cause mine is extremly loud.
