difference in et with stall converter
How much dif. between stock and higher stall? If you went 12.8x with the stock one will you still go 12.8x with a 9/11?
Lynn D. Brown
TC
TC
Mav.,
Not sure U would see any diff if U changed only the TC. The main advantage that the Hier Stall TC will give U is the ability to rev the engine to a hier RPM and HP at the line, therefore getting more boost and a better 60' time. However, U often have to increase the HP of the engine to be able to actually get off the line at that hier RPM.
