difference between walbro pumps
ABLITZ
Damn Yankee
what is the difference between a walbro GSS346 and a GSS307.i have a GSS346 in it now.should i leave it in or put the GSS307 in?which is better?
ABLITZ
Damn Yankee
that e-mail doesnt work,but thats ok i got another addy off his site.need an answer kinda quick, got the tank down, gas all over the place :oops:.
TIA!!
What's a 346?
A 340 is the high pressure 255 liter/hour. The 307 used to be the same as the 340 except for lower bypass pressure. The new 307 has a different armature and some other things. The flow charts are available on gnttype.org comparing the two.
If the 346 is not a 340 than I'd say go with the 307. It good for at least 550HP according to Joe and Harry at PTE. HTH,
ABLITZ
Damn Yankee
thats the number right on the pump(GSS346).dunno maybe an older model??wish i could put the 307 on there BUT i cant get the filter that goes on the bottem of the pump on.its not tapered so i cant slide it on.
forgot to add:it also has holley stamped above where it says walbro.
ABLITZ
Damn Yankee
ok got an answer from Ron Gregory.
the GSS346 is the same exact pump as the GSS307.only difference is one(GSS346) has holley stamped on it.
