TurboCharlie and QWERTYphoon,
Well, we are pretty close in our purposes in that my ride also is a bastard clone of grand proportions.
My 1950 Studebaker Champion is sitting on a 1986 S10 4WD - standard cab/long bed - frame where eight (8) of the body to frame bolts lined up perfectly. My engine is old school rather than "New School LS," being a built 1975/76 Cadillac 500 CID bored 0.050 over for a total of 511.5 CID. Being greedy I round it off to 512!
The engine had enough compression to bark when run on the break-in stand, so much so that it will be interesting to see if the E85 fuel, plus water injection will be enough to cover the anticipated 18 pounds of boost from the mid-mounted twin Garrett 3782 turbochargers.
Running gear includes a refreshed front differential, GM 4L85E transmission, backed by a low mileage but rebuilt NVG 149 AWD transfer case from a 2003 Silverado. The rear is a Ford 8.8 IRS unit from a 1995 Thunderbird SC. It has been bolstered with a Torsen limited slip unit. Both front and rear diffs have 3.08 gear ratios as the expected prodigious torque should be more than enough to be interesting.
I wish you both well with your projects!
Darius
dba, bro. d
