FYI, replacing that oil line is a huge PITA.
To take it off, I first used a small flat screw driver to get in that band clamp and twist and twist until I was able to get a bigger screw driver to twist and twist until it broke off (x2).
Then use a razor blade/box cutter to cut the hose. Again, huge PITA. Had to get that sucker off.
To get the NEW hose on there (bought from SportsMachine), lubricate the oil line pipe w/some ATF and shove the hose (along w/loose hose clamps) up that oil line pipe. Then shove it back down onto the other end/fitting.
Uggh...
