75lb Injector/Chip/ECU Package
1BADV6
This is a 75 lb injector package, it includes six flow matched injectors, a Phil Long 75lb multi chip with Moates remote program selector and a modded factory ECU for the 75lb injectors. The chip is setup for Vortec heads, 422 cam and 60 series turbo. This combination has been proven to run low 11's in a Typhoon and high 10's in a Syclone. These parts are practically new with less than 500 miles of use. Over $800 invested, I am asking $450 for the complete package including shipping.
thanks,
TYHOGG
Re: 75lb injector package
interested. can you explain more about the chip? i haven't seen that before. I take it the ecm is modded because these are low impedence injectors?
1BADV6
It is a Phil Long chip, you can probably search on here and find much more info. It has multiple tunes with each one utilizing slight changes in fueling and timing and the selector switch allows you to switch between tunes to find the "sweet spot" for your particular truck. I believe CLONEMAN315 on this list is running a similar combo in his 10 second Syclone. Yes, the ECU was modified with drivers to work with the low impedence injectors.
thanks,
1BADV6
TTT Price lowered to $450 including shipping in the lower 48 states.
0966Sy
Code what?
Good setup for anyone trying to go fast, it is a racechip although. Can be used on pump gas. And a great package price
1BADV6
Re: 75lb Injector/Chip/ECU Package
If I recall Phil recommended a Walbro 255 fuel pump with his chips. You will also need an AFPR.
Syty84
What fuel pump are you running, and how well did the tune work for you?
1BADV6
I never ran it, decided to go with a full bowtie build and BigStuff3 on that truck..... You need to contact Cloneman315 on this list and talk to him about this setup.
